Forums Forums K3 Dashcam K3 Reboots
  • K3 Reboots
    Posted by archer08 on 2024-07-01 at 03:21
    K3 keeps rebooting and cannot connect to wi-fi. Blue light on power supply is blinking. Camera light comes on gps comes on blinks once and stays on. Wi-fi light blinks 4 times and goes out. Then camera and gps light go out and it starts over. Installed update on sd card but no change.
    Hans replied 2 years, 1 month ago 2 Members · 1 Reply
    2024-07-01 at 23:45
    Hi Alex,
    If the blue LED on the power supply flashes, I suspect a power supply problem. See also the labeling of the power supply. When starting up the K3, too much power is required which cannot be supplied. Can you also measure your battery voltage?
    Can you power the K3 with a power bank via the USB connection? First disconnect the power supply. If this does not help, try to disconnect a part (behind camera, front camera, etc.) to see if one of these parts prevents the K3 from restarting.
