Forums Forums K6 Dashcam K6 live-streaming use case
  • K6 live-streaming use case
    Posted by grigoreo on 2024-07-09 at 23:10
    Hello.
    I want to use K6 for live streaming. I don’t care much about recording.
    I’ve already discovered rtsp stream, and commands.
    The problem is that rstp stream is only 480p/h264.
    Is it possible to tune the camera to produce two(F&R) parallel 1080p/h265 streams?
    Hans replied 2 years ago 2 Members · 3 Replies
  • 3 Replies
    2024-07-09 at 23:42
    Hi Greg,
    I don’t have an answer to your question. But I’m curious how you got streaming active.
    I would like to know how you do this and with what commands.
    • grigoreo
      2024-07-10 at 19:20
      Hello!
      Streaming is active by default actually, it used as a preview feature in mobile app.
      It’s just an rtsp stream which is available as rtsp://192.168.1.254/. I use VLC player to watch it.
      The command 3028 is used to switch streaming modes.
      Parameters are
      0 =
      Front Cam only
      1 = Rear Cam only
      2 =
      Front Cam major, Rear cam small
      3 =
      Rear Cam major, Front cam small
    2024-07-10 at 23:33
    Greg, thanks for the info.
    I’m going to experiment with this too.
