Forums › Forums › K3 Dashcam › Where is the old forum?
    2024-07-18 at 15:50
    Hi Jozsef,
    Unfortunately the old forum is no longer active. The content of this old forum has not been transferred to the new forum. This is because the new platform runs on a different system than the old platform.
    I suspect you are looking for information on how to connect the K2 to a computer using a web browser. Fortunately, I have saved some information from the old forum. So hopefully the below is what you’re looking for (thanks to Frostie).
    K2 connectie met laptop
    Using a Laptop would be the easiest way.
    Connect your laptop to the K2 by wifi and open a web browser. Then enter the following URL to check you are connected.
    http://192.168.1.254
    You should then see a simple website, which gives you access to the sd card of the K2. If you see this page, you are ready to send commands.
    Before changing the brightness, you should stop recording first. Just enter.
    http://192.168.1.254/?custom=1&cmd=2001&par=0
    Now you can change the brightness, using this command.
    http://192.168.1.254/?custom=1&cmd=2005&par=X
    …with X ranging from 0 (lighter) to 12 (darker). Default is 6.
    So entering e.g. http://192.168.1.254/?custom=1&cmd=2005&par=12 will set the K2 to the darkest brightness setting.
    Now restart recording by entering
    http://192.168.1.254/?custom=1&cmd=2001&par=1
    To check the result, you can directly download the recorded videos on the website. Before doing this, you should again stop recording by entering the URL mentioned above.
    So the steps are.
    http://192.168.1.254/?custom=1&cmd=2001&par=0 <- Stop recording
    http://192.168.1.254/?custom=1&cmd=2005&par=X <- Change brightness
    http://192.168.1.254/?custom=1&cmd=2001&par=1 <- Start recording
    Wait a minute
    http://192.168.1.254 <- Download video
    Check brightness in video
    The K2 will revert to default brightness when it reboots.
    • terryfrench
      2024-08-03 at 12:23
      The app should be updated, as we get a 404 error page clicking on the forum and I think FAQ on the app.
      A link to this forum should be added to the innovv.com web site, otherwise other than google, there’s no way to find the forum.
      I’m a brand new K7 owner and that part is disappointing.
        2024-08-03 at 22:48
        Hi Terry,
        I hope Innovv will adjust the app soon.
        On the Innovv website, the forum can be found under Explore – Forum.
        @INNOVV
        Would you like to implement the changes in the app?
  • yokci
    2024-07-20 at 21:06
    Thank you!
    Finally I found Frostie.
