Forums Forums K6 Dashcam App connection
  • App connection
    Posted by ebikecommuter on 2025-02-08 at 07:29
    I have the k6 bicycle version and was wondering if the camera needs to be connected to the app to record or will it still record to the SD card and I can connect to the phone later to view? I like to stream music while I ride and when the camera is using the phones wifi connection I can’t to that. Also how can I tell if the camera is recording of im not being the app? Thank you
    Hans replied 1 year, 5 months ago 2 Members · 1 Reply
    2025-02-08 at 14:21
    Hi Graig,
    You don’t need the app to record.
    The app is needed if you want to adjust settings in the K6 or download videos to your phone.
    To avoid conflicts with streaming, I advise you to set the wifi timer as short as possible. For example 2 minutes. Please note that if you are going to download videos, you set the wifi timer longer.
    You can see the status of the wifi and recording using the LEDs (green/red). See also the user manual, which can be found at https://innovv.com/pages/k6-dashcam-support
