Forums › Forums › N1 Pro › Power up test via USB C port?
  • Power up test via USB C port?
    Posted by cbudensiek on 2025-03-18 at 10:40
    I am would like to power up and test the N1 Pro unit before installing on my motorcycle. Am I able to power it up as a test via the USB C port next to the memory card slot?
    I have tried this with two different power sources, two different cables, SD card installed, SD card not installed, no cameras connected, one camera connected, and both cameras connected. Yet, the screen does not turn on. Am I missing
    Hans replied 1 year, 6 months ago 2 Members · 1 Reply
    2025-03-19 at 00:06
    Hi Charles,
    You can power the N1 Pro with the USB C port.
    Make sure you use a USB power supply that has enough power to power the N1 Pro. I tested with a USB power bank with a capacity of 10,000mAh. It should not matter whether or not you have inserted an SD card and whether or not you have connected cameras. My N1 Pro had an SD card installed and both cameras were connected.
