Forums Forums K5 Dashcam No videos shown in App Reply To: No videos shown in App
    2025-06-28 at 17:36
    Hi Nitro,
    Did you format the SD card using the Innovv?
    Even if you removed the SD card from the K5 and then put it in a computer, it is recommended to format it again with the app when you put the SD card back in the K5.
    The videos are also not under protected or accident videos?
    The IP address of the K5 can be 192.1681.254, otherwise you can use the command ‘arp /a’ with the command window. Then you will see everything within your network.
