Forums Forums K3 Dashcam Dead K3
  • Dead K3
    Posted by balder on 2025-05-11 at 18:04
    I have a K3 that has stopped working. Remote control is dead. Converter lights up constantly blue. Can’t connect to app. When I connect a power bank to the DVR everything works as it should. I have downloaded new firmware.
    balder replied 1 month, 4 weeks ago 2 Members · 2 Replies
  • 2 Replies
  • Frostie
    2025-05-12 at 14:10
    Hi Hakon,
    as the DVR starts when you connect power to USB, the DVR seems to be ok.
    The steady blue led at the power converter means that it still senses the voltage of the battery, but does not sense switched power at the yellow cable. To check the power converter, you could connect the yellow wire directly to + at the battery. After some seconds, the blue led should start blinking and the DVR should start.
    If the led starts blinking, then you need to check your connection of the yellow wire to switched power.
    If the led does not start blinking, then is seems that your converter is faulty and you need a new one.
    Regards,
    Marc
    • balder
      2025-05-13 at 02:51
      Hi.
      Thanks for the reply.
      I have used Hex ezcan as a power source, with its own circuit for yellow.
      I connected red and yellow together, so now it works as it should.
      THANKS. 🙂
