Forums Forums K6 Dashcam Green light not always coming on
  • Green light not always coming on
    Posted by troyite on 2024-09-26 at 00:31
    My K6 is mounted to a motorcycle. When it works it is great.
    However many times when I start up my bike the light flashes red and green and does not go green.
    If I take out the SD card and put it back in the light goes green and the cameras record.
    What can I do to make it power up correctly and not have to take the SD card out as this is very annoying and time consuming?
    Hans replied 9 months, 1 week ago 2 Members · 1 Reply
  • 1 Reply
    2024-09-26 at 01:41
    Hi Richard,
    The green LED indicates the status of the WiFi but can also mean that a recording is being made. Fast flashing has to do with the WiFi. Slow flashing has to do with recording. With recording, the red LED should also be on continuously. Unfortunately, the manual is not entirely clear on this.
    It seems to me that the K6 WiFi is trying to connect to your phone but that this connection is not found. If there was a WiFi connection, the green LED should be on continuously.
    Perhaps the WiFi connection is not going completely well. This can happen if you are using an iPhone. The tip is to put the iPhone in airplane mode and manually establish the WiFi connection.
    In addition, a bad/wrong SD card can also cause strange problems. Can you format the SD card using the app? And does the SD card meet the specification as stated by Innovv in the manual?
