Forums Forums K3 Dashcam INNOVV K3 WIFI light not lighted after changing the battery.
  • INNOVV K3 WIFI light not lighted after changing the battery.
    Posted by adrian on 2024-09-13 at 13:27
    Recently i have change my battery as it is due. After changing, WIFI and GPS signal not lighted after i switch on the ignition of my bike. I am not able to connect my WIFI to INNOVV app.
    Hans replied 8 months, 2 weeks ago 2 Members · 8 Replies
  • 8 Replies
  • adrian
    2024-09-13 at 13:35
    Recently i lost the micro SD card in the bike while removing. I bought a new compatible micro SD card. Can i just download the firmware and transfer the file to the new micro SD card and update the DVR? Please advise.
    2024-09-15 at 00:23
    Hi Adrian,
    you can put the firmware on your new SD card without any problems.
    Make sure you put the firmware file in the root of your SD card.
    At the power converter, is the blue LED still on? If not, there is a problem with your power supply. Perhaps a connector is no longer properly connected.
    It is possible that the K3 was turned on by the parking mode while changing your battery. You will undoubtedly have moved the motor while changing the battery. If the K3 then turned on and you disconnected the power supply, the SD card may have become corrupt. Can you format it in your computer and then see if the K3 starts up properly?
  • adrian
    2024-09-15 at 11:40
    You meaning of root is it in FAT32 ?
  • adrian
    2024-09-15 at 11:40
    The blue LED is not lighted.
  • adrian
    2024-09-15 at 11:41
    I will give it a try. Thank you.
    2024-09-15 at 23:05
    Hi Adrian,
    In the root I mean that the firmware file is not placed in a folder on the SD card. In a FAT32 formatted SD card, the firmware file is the only file on the SD card. So no other files or folders are present.
    If the blue LED does not light up, there is a problem with the power supply. Check whether the fuse is still intact.
    You can also disconnect the power converter from the K3 and power the K3 with a power bank using the USB connection. The power bank must be able to supply enough power. If the K3 then works, you know that the problem is with the power supply.
  • adrian
    2024-09-17 at 13:05
    Thank you. I will check it out.
    2024-09-20 at 15:44
    Hi Adrian,
    Let me know if it worked.
    If you have any questions, please let me know.
