Forums Forums K6 Dashcam Innovv K6 USB not automatically powering up
  • Innovv K6 USB not automatically powering up
    Posted by colr on 2024-07-24 at 15:07
    Hi
    I have a BMW 1300GS. I have installed the camera system. The power source for the camera is from the 12 volt outlet via a 12V to USB converter. The camera powers up and work perfectly (when I manually power the camera up), but does not automatically power up automatically when the bike powers up.
    Can you please assist me.
    Thank you
    Hans replied 10 months, 2 weeks ago 2 Members · 1 Reply
  • 1 Reply
    2024-07-25 at 00:57
    Hi Collin,
    To start the K6 when the ignition is turned on, you must supply the K6 with power using the DC converter.
    With the DC converter you have an extra connection, the yellow wire that works as a trigger to turn the K6 on and off when the ignition of your motorcycle is turned on and off.
    The way you currently supply the K6 with power does not have this trigger function. This is actually the option for installation on a bicycle where you cannot use a switched power supply as a trigger.
