Forums Forums K3 Dashcam K3 wifi
  • K3 wifi
    Posted by Gus Fuhrer on 2024-01-05 at 07:54
    Does the wifi automatically turn off after about 5 minutes? I noticed the light for wifi on the remote turns off after riding for about 5 minutes.
    Gus Fuhrer replied 1 year, 5 months ago 3 Members · 3 Replies
  • 3 Replies
  • Jade
    Moderator
    2024-01-05 at 09:55
    Hi, Gus
    Usually the wifi will automatically turn off after the active duration time of wifi.
    Please check this in INNOVV app and set up it as you need.
    The attached photo is for your reference.
    2024-01-06 at 01:24
    Hi Gus,
    Indeed, as Jade mentioned, you can set in the app whether and after how long the WiFi should be turned off.
    To enable WiFi again, the K3 will have to be switched off and on.
  • Gus Fuhrer
    Guest
    2024-01-15 at 03:34
    That was the issue. Got it all sorted out,thanks.
