Forums Forums K6 Dashcam Need to unplug and re-plug to start
  • Need to unplug and re-plug to start
    Posted by jack223 on 2025-03-15 at 17:17
    Hi all,
    I’m running the K6 on my bicycle. The camera turns on as expected with the described 3-sec button push after I have connected it to the battery. However, after turning it off again, the camera cannot be turned on again. I need to un- and re-plug the battery in order to start it again. Is this expected?
    jack223 replied 3 months, 2 weeks ago 2 Members · 2 Replies
  • 2 Replies
    2025-03-15 at 17:43
    Hi Jack,
    Is this only shortly after switching off that you can no longer switch on the K6? Or is there a longer period of time between switching off and switching on again?
    Do you also have this problem with a different battery/USB power supply?
    Also try reflashing the firmware.
    • jack223
      2025-03-15 at 19:55
      It’s practically immediately after switching it off that it can’t be turned on again. Unfortunately, I couldn’t test if this happens with a different power supply too. It’s a good idea, obviously. I’m always a bit hesitant when it comes to firmware flashing, especially given that there are power problems. I may try this too.
