Forums Forums K3 Dashcam Remote control camera light flicker then turns off and on again.
  • Remote control camera light flicker then turns off and on again.
    Posted by skylar on 2025-06-28 at 23:30
    The camera light on my K3 remote control… flickers and then stays still followed by turning itself off and then on again. It keeps going on like this. I did an update to the software and reset the dvr… Still the same. Have Anyone encountered this before ??
    Hans replied 4 days, 9 hours ago 2 Members · 1 Reply
  • 1 Reply
    2025-06-29 at 12:06
    Hi Skylar,
    Is the blue LED of the power module on?
    Do you have the problem when the engine is not started or also when you are driving?
    It is possible that if the supply voltage is not sufficient, the K3 cannot start up. Especially when the wifi starts up, this requires more power. If this power cannot be supplied, the K3 will restart.
    Try starting up without an SD card.
    You can also disconnect the cameras, GPS module or remote control one by one to see if one of these modules has become defective and therefore does not allow the K3 to start up.
