Forums Forums K3 Dashcam Remote not working
  • Remote not working
    Posted by markiemark on 2025-06-23 at 16:03
    I took my K3 system of my old bike and put it on my new bike. Now I’m not able to connect to the remote anymore.
    I have a solid camera light (green) and then its starts blinking and searching the gps (always blinking, never get a solid light) and in rare occasions the wifi (blue) appears for a very short time. All three lights are blinking then. Sometimes i can spot it on my phone but then the signal is gone already when i want to connect.
    It does the same when power is from a external powerbank. Light connector is solid blue when off and blinking when contact motorcycle is on.
    What could be the prolem?
    • This discussion was modified 1 day, 22 hours ago by  markiemark.
    Hans replied 1 day, 12 hours ago 2 Members · 1 Reply
  • 1 Reply
    2025-06-24 at 02:05
    Hi Mark,
    I would first check all connectors to see if they are properly connected and have no (moisture) damage.
    Also check the power supply connections. The fact that the power LED lights up blue when the engine is off and flashes when the engine is on is not a good sign. Have you connected the yellow wire properly to a switched power supply?
    What happens if you remove the SD card, does the K3 boot properly? Also try reloading the firmware.
