Forums Forums K7 Dashcam SD Card Size
  • SD Card Size
    Posted by Becsta on 2024-11-14 at 10:09
    Hi it says to update firmware to use an sd card from 8-32 gb, is 32gb the largest card that can be used in the K7 or just for firmware updates?
    Frostie replied 6 months, 2 weeks ago 4 Members · 3 Replies
  • 3 Replies
    2024-11-14 at 16:00
    Hi Becsta,
    The 32GB limit is only for updating.
    For normal use the limit is 512GB.
  • Bob
    2024-11-15 at 01:30
    I used a 128GB card with no issues.
    My guess is this is an old suggestion, but I will put the question on my list.
    • Frostie
      2024-11-18 at 22:03
      The 32GB recommendation comes from the necessity that the sd card must be formatted in FAT32 for the update process to work.
      As FAT32 does not support volumes larger than 32GB, every OS will deny formatting the card in FAT32. So if a sd card is larger than 32GB, it is very likely not formatted in FAT32.
