Forums Forums K6 Dashcam SD Cards
  • SD Cards
    Posted by fred on 2025-04-14 at 22:50
    Hallo, I am planning a multiday trip with my GSA in Wales. I expect my current SD-card to be full every evening. I hope to view trip at the end and edit most of it but before doing that I don’t want to lose items. Since I don’t want to carry my computer along I thought about buying several SD-cards but this is cumbersome. Anybody any ideas on how to solve this in another way? WD had a solution but they stopped making it (My passport Wireless Pro). Thank you
    adamgiles replied 1 month, 2 weeks ago 3 Members · 3 Replies
  • 3 Replies
  • adamgiles
    2025-04-15 at 00:09
    Bigger card..?
    2025-04-15 at 00:35
    Hi Frederic,
    The maximum size of the SD card or the K6 is 256GB. If you look at how big your recordings are, you can calculate how many (minutes) recordings you can make on one SD card. Depending on how many days you want to record, you can determine how many SD cards you need. Changing SD cards is the least complicated method in my opinion.
    I don’t think My Passport Wireless Pro will work with an Innovv camera.
    It is advisable to format all SD cards in the camera in advance using the Innovv app.
  • adamgiles
    2025-04-15 at 15:18
    I calculate you should get approx 20hrs on a 256 card recording at 2k 30fps. (Haven’t proved this yet, so do your own calculations). Using HD and/or 28fps should increase this.
