Forums Forums K6 Dashcam Wi-Fi auto connect
  • Wi-Fi auto connect
    Posted by mgfromnc on 2025-04-27 at 06:13
    Everytime I go to log in to the camera it requires me to connect, pick the innov network, then it connects.
    Is there anyway to have it auto connect when you open the app?
    mgfromnc replied 2 months, 2 weeks ago 3 Members · 3 Replies
  • 3 Replies
  • adamgiles
    2025-04-27 at 06:20
    Whilst you are connected to K6, checked your WiFi settings on your phone. You should have an “auto reconnect” option. Make sure it is switched on.
    • This reply was modified 2 months, 2 weeks ago by  adamgiles.
    2025-04-27 at 15:11
    Hi Michael,
    Your phone is probably already connected to another wifi network and will not search for another wifi network (Innovv Wifi). Unless you set all other wifi networks to not connect automatically and only set the K6 wifi as auto reconnect. Maybe it will work then, but then your phone must first lose the connection to the existing connection. You must then also always manually connect the other wifi networks.
  • mgfromnc
    2025-04-28 at 02:40
    That would be the answer indeed. I don’t see the value is holding open the Wi-Fi connection from the phone for the few times I’d need it for the DVR.
    Thank you all for your help
