Forums Forums H5 Helmet Cam Wind noise from camera mic
  • Wind noise from camera mic
    Posted by gebe on 2024-06-13 at 02:01
    Hi, I look for a solution about the wind noise. I dont have the external mic. I use the mic on the H5 camera and the wind noise is very disturbing, even with the volume at 1.
    Thanks for your help!
    Hans replied 1 year ago 3 Members · 3 Replies
  • 3 Replies
  • Steve
    2024-06-13 at 03:37
    Iv got an external mic,and a power pack ,I put it in my inner jacket pocket,(no use inside helmet as its a bit bulky ) I have lambretta scooters, volume 2, and it really only affects the quality if in doing 75 to 80 mph…..yes…tuned lambrttas do up to 100mph these days, (the noise is the only problem.i have wi the H5, wish there was a proper fix for this )
    • gebe
      2024-06-13 at 06:42
      Thanks, it’s a good option, I already have a power tank.
    2024-06-13 at 15:26
    Hi Gaétan,
    Recording sound properly with the H5’s standard microphone remains difficult. I experimented myself by putting a piece of tape over the microphone opening. This only helps partially and is not a 100% solution.
    To make a good recording, I recommend that you purchase the separate microphone unit. I built this into my helmet. In the photo you see the standard Schubert microphone with the H5 microphone built into my helmet (Schubert C4 Pro) underneath. Both are equipped with a foam windshield. With this setup I can make good sound recordings.
