Forums › Forums › K6 Dashcam › K6 Rear Camera Does not Retain Image Orientation Settings › Reply To: K6 Rear Camera Does not Retain Image Orientation Settings
Hi Martin,
The maximum capacity of the SD card is 256GB, see also the manual. I use a Samsung Evo 256GB SD card myself. This works without any problems. Updating with a 256GB SD card also works without any problems for me. With a 32GB SD card it will quickly be filled with recordings.
I think there is only one kind of firmware version. The difference between the motorcycle version and the bicycle version are the mounting materials and the power supply. On the motorcycle you can use the power module, on the bicycle you use a power bank with a USB connection. See also the manual.
The latest version of the firmware can be downloaded from the Innovv website. Look at the menu ‘support’ – ‘app/firmware/manual’ – ‘K6 Dashcam’ – ‘Firmware’.
This reply was modified 1 year, 1 month ago by
Hans.
