Forums Forums N1 Pro Cameras for N1 vs K3
  • Cameras for N1 vs K3
    Posted by Phil on 2024-12-31 at 23:54
    Are the cameras for the N1 identical to what was used in the K3? Reason I ask is I just received an N1 for my Can-Am Spyder and it has a K3 installed already. If I don’t have to re-route cameras, I would just leave the existing K3 cameras in place.
    Thoughts??
    Hans replied 1 year, 2 months ago 4 Members · 9 Replies
  • 9 Replies
    2025-01-01 at 20:29
    Hi Phillip,
    The cameras of the N1 and the K3 have different connectors. These will probably not fit together.
    In addition, the CMOS (heart of the camera) is also different. I suspect that you cannot interchange them. The K3 CMOS is a Sony Starvis 291. The N1 has a Sony Starvis IMX307.
    So you will have to Google yourself whether these are technically interchangeable. Whether the firmware of the N1 is suitable for this….. I suspect not.
    • oconnoradv
      2025-01-04 at 01:36
      Your assessment is accurate; though the N1/N1-Pro have a published max resolution (somewhat misleading as it is the only option) they are currently hardcoded to work at the specific resolutions/fps of the included cams and cannot dynamically or manually adjust to a different camera feed. I attempted to attach my FLIR camera to it (because I presumed they would support lower resolution options as the K series did). After many frustrating hours (assuming I had messed up my custom wiring), I confirmed with support that the N series currently only supports the specific parameters of the included cameras.
    • wheeler
      2025-06-26 at 08:10
      Would it be possible to buy an adapter to make them compatible?
        2025-06-26 at 16:36
        Hi Dave,
        Hardware wise the cameras are different. There is no adapter to make them compatible. I think you will be cheaper off by buying the right cameras. With an adapter (if one exists) the chance of malfunctions is also greater.
  • Phil
    2025-01-01 at 21:53
    Thanks for the reply. I figured there were positive changes in the N1 vs. the K3 so I will just drag a pull string through when I install the N1 on the Can-Am. The Can-Am is very packed under the handlebar area and one needs small hands to get in there. Have a safe and Happy New Year.
    2025-01-05 at 17:59
    Hi Phil,
    Good luck with the installation of the N1.
    If the installation is successful, could you post some pictures? This might help other Cam-Am Spider drivers install their N1.
    Have fun with your N1.
  • Phil
    2025-01-05 at 20:54
    Will do. The Can-Am is easy to work on but there are some tight spots that hands don’t really fit. LOL
  • Phil
    2025-05-17 at 01:26
    OK, Indiana weather finally cooperated to install this N1. I like it, wish there was a way to remove the head for overnight outside but hopefully a cover deters. I will post pictures in a few days. I’m trying to figure it out.
    2025-06-26 at 16:11
    Hi Phil,
    Perhaps you know someone who is handy with a 3D printer and can make a cover?
    I would like to hear your experiences with the N1.
