Forums Forums K6 Dashcam no audio
  • no audio
    Posted by dude on 2025-04-24 at 13:19
    bought and install two k6 on my bikes, one works perfectly, but second one has no audio. Checked manual, only two option of such problem: mic is off, but I checked twice its on level-3, second one microphone input hole might be blocked. Any idea why ?
    Hans replied 1 month, 1 week ago 2 Members · 3 Replies
  • 3 Replies
    2025-04-24 at 14:33
    Hi Eduard,
    I assume that you have set both K6s the same.
    If the microphone input were blocked, you should still hear on the recording that you are tapping the housing with a hard object. The microphone input is a small hole, so it can quickly become clogged with dirt.
    You could still perform a hard reset:
    • Switch on the K6
    • Press and hold the power button for a long time (about 30 seconds)
    • The red LED flashes 2x and then goes out again
    • Restart the K6, K6 has been reset to factory settings.
    If necessary, flash the firmware again after this reset. If you still have no sound, then I think there really is a technical problem with the microphone.
    • dude
      2025-04-24 at 15:37
      appreciate!
      noticed for next time.
      It seems like problem solved themselve…I played a video from yesterday try, and it was with sound!!! I dont know, what happened yesterday with the files i tried to watch, but it works today.
      anyway thx a lot.
    2025-04-24 at 18:11
    Hi Eduard,
    Maybe it was something simple, like the mute button🙂.
    But it works, again, and that’s what matters.
    Have fun with your K6.
