Forums Forums N2 Failure to download
  • N2
    Failure to download
    Posted by rocket on 2025-10-07 at 16:16
    Hello all,
    I have tried and tried to get my n2 to download footage to my phone to no avail.
    Correct me if I’m wrong please.
    1 turn on unit
    2 open app on phone.
    3 go to phone wifi settings and connect to camera wifi.
    4 in app select camera files.
    Each time I try to do this it just gets in a loop asking me to accept camera connection.
    When I check wifi my phone reports excellent connection and strong signal.
    I got rid of my n1 pro in favour of the n2 so I could download footage without removing the SD card.
    So far it won’t do that!
    Hans replied 1 week, 6 days ago 6 Members · 14 Replies
  • 14 Replies
  • Frostie
    2025-10-07 at 16:53
    Hello,
    try switching your phone to Airplane Mode before connecting to the N2.
    Regards,
    Marc
    2025-10-09 at 15:11
    Hi Christopher,
    You don’t have a VPN connection enabled? If so, disable it.
  • jack
    2026-02-28 at 15:04
    While N2 is booting you need to tap download before the home screen can load.
  • Charles
    2026-03-20 at 00:51
    I am in the same boat… I can watch my cameras live on my phone, so I know im connected, but when I go to videos, it’s empty on my phone..
      2026-03-20 at 17:05
      Hi Charles,
      To watch your videos on your phone, you must first download them.
      You can view them either directly from the camera (Camera Files) or after downloading them from your phone (Local Files)
  • Charles
    2026-03-20 at 22:52
    That’s the issue, they won’t download to my phone…..
  • Charles
    2026-03-20 at 22:54
    When I get to the innovv download screen and hit download, nothing happens..
  • Charles
    2026-03-21 at 00:59
  • Charles
    2026-03-21 at 01:00
    0:08
    20260320_095941
    0:08
      2026-03-21 at 19:42
      Have you already tried downloading the videos using the Innovv app?
      Connect to the N2 and open the app.
      Select Document, Camera Files, Continuos Videos. Wait until the video thumbnails become visible. Click on a thumbnail and select download.
  • Jeff
    2026-07-22 at 21:23
    I am having same issue. Were you able to get this resolved Should have to disable phone to get this to work
      2026-07-23 at 00:51
      Hi Jeff,
      To download the videos, use the app; see my previous message above. The N2 therefore does need a Wi-Fi connection to your phone.
  • Jeff
    2026-07-24 at 03:55
    I was able to resolve this issue. You have to reset unit to get to download screen. Realease all prior N2 Android connections & N2 bluetooth. Meaning you have to be at initial screen. You then have to connect to N2 without internet. No Android Auto. No N2 Bluetooth. Follow instructions in screen. It works but a very cumbersome process.
    • This reply was modified 1 week, 6 days ago by  Jeff.
      2026-07-24 at 15:49
      Hi Jeff,
      Just to clarify, are you talking about downloading videos, not downloading the firmware?
      Can you show photos of what happens when you press the download button? For example, are you asked where you want to save the videos? What do you see happening in the app?
      And were you also able to download the videos in the app as I described earlier? With the N1 and N3 and other Innovv cameras, this is actually the easiest way to download the videos. You don’t have to disconnect or reset anything. The only thing you need to do is establish a Wi-Fi connection with your camera.
