Forums Forums K7 Dashcam K7 randomly stops recording and restarts recording during rides Reply To: K7 randomly stops recording and restarts recording during rides
    2025-11-20 at 23:47
    Hi Davide,
    You can reduce the sensitivity of the G-sensor. This will result in fewer/no recordings being saved as ‘protected’. Aren’t the missing recordings in the subfolders mentioned? I’m also guessing you also have the Loop Recording Duration set to 1 minute.
    The K5 and K7 manuals are indeed slightly different.
    In the K7 manual, “protect video” is listed twice in the LED indicators, which doesn’t make it any clearer. But when I look at my K3 and K5, they flash twice within one second if it’s a protected video.
    Just to be sure, did you format the SD card using the Innovv? If you formatted the card using a computer, the K7 might have some difficulty with the SD card and might not respond properly.
