Forums › Forums › N2 › gloves!!!
  • N2
    gloves!!!
    Posted by karl on 2026-01-03 at 07:53
    I have no touch screen operation with gloves on (even with touch tips on them) but my cheap carpuride worked fine with my gloves on ……..not good for a motorcycle specific item
    Hans replied 9 months ago 2 Members · 5 Replies
  • 5 Replies
    2026-01-04 at 18:41
    Hi Karl,
    Does the N2 work well without gloves?
    Are you able to test it with different gloves? In my experience, with gloves on, it’s sometimes harder to feel if you’re touching the touchscreen correctly with enough pressure.
    Are you using a screen protector?
  • karl
    2026-01-04 at 18:46
    Yes the screen works well without gloves, tried 2 different pairs (both winter gloves). no screen protector as I removed that to check it wasn’t that causing the issue
    • This reply was modified 9 months ago by  karl.
    2026-01-06 at 02:46
    Hi Karl,
    I currently have no idea what the cause could be. Has it worked with your gloves before? I don’t have N2 myself, so I can’t test this myself.
    I think it’s best to contact Innovv directly to resolve this issue: [email protected] or https://innovv.com/pages/contact
    I assume you purchased the N2 directly from Innovv; if not, please contact your seller.
  • karl
    2026-01-07 at 01:03
    The unit is brand new never used no screen protector on it. My gloves have touch pads on the fingers etc so should work (have done on my old carpuride unit) so I have contacted support so hopefully they can help me
      2026-01-07 at 18:31
      Hi Karl,
      I’m curious to see how it goes.
      There are different types of touchscreens: pressure-sensitive and capacitive etc. This could be the difference between the N2 and the Carpuride. However, that doesn’t change the fact that the N2 should be operable while wearing motorcycle gloves.
