Forums › Forums › H5 Helmet Cam › Camera View
  • Camera View
    Posted by Rob on 2026-03-22 at 04:13
    Is there a way to change the camera view? I mount my camera on the fairing of my motorcycle, but the mount only allows for it to be mounted on its side. Is there a setting to rotate the camera angle by 90 degrees so that my recordings are not sideways?
    Hans replied 7 months, 3 weeks ago 2 Members · 1 Reply
  • 1 Reply
    2026-03-22 at 19:03
    Hi Rob,
    Unfortunately, rotating 90 degrees is not possible. The H5 was released for helmet mounting, and therefore there is no way to mount the H5 rotated 90 degrees. It is also not possible to rotate the image using software (camera sensor ratios).
    Do you know anyone with a 3D printer who can print a modification for you? Or you would have to rotate all the images using video editing software.
