Forums › Forums › K6 Dashcam › Cameras get hot
  • Cameras get hot
    Posted by Brummienick on 2026-08-18 at 02:12
    I just bought a K6 and thought I’d check it all works ok before installing it by connecting it to a 12v battery on the workbench. It all seems to work ok and I can view and retrieve recordings via the app. I did notice however that the front camera gets quite hot after a few minutes of operation, the rear camera also gets warm but not as hot as the front – is this normal?
    Brummienick replied 2 months, 4 weeks ago 3 Members · 4 Replies
  • 4 Replies
  • adamgiles
    2026-08-18 at 02:32
    The camera and DVR will get warm when running. The metal case acts as a heatsink. Once on your motorbike there will be a constant flow of air to help dissipate the heat.
    I have recently used my K6 in Southern Italy with no heat issues.
  • Brummienick
    2026-08-18 at 02:40
    Thanks Adam
    2026-08-18 at 03:16
    The front camera contains the processor, and it gets warm.
    The front camera can certainly get warm at a high resolution and bitrate setting, but not hot. You must be able to touch the front camera with bare hands at all times.
  • Brummienick
    2026-08-18 at 15:02
    Thanks Hans, that sounds about right. Yes “hot” is subjective, it didn’t get so hot that I couldnt hold it. Looking forward to getting it fitted to the bike now that I know it’s working normally.
