Forums Forums K6 Dashcam Consistent SD Corruption
  • Consistent SD Corruption
    Posted by lukec on 2025-06-20 at 23:03
    This is most frustrating, I’m burning through SD cards at a rate of knots with this to the point I wish I never purchased it now.
    I’ve purchased the recommended cards in a variety of makes and capacities and finding that they corrupt sometimes within days, sometimes within weeks or months depending on how big the capacity is for the card.
    Anyone else had this issue? I’ve worked through all the trouble shooting, checked the adaptor is fitted security to prevent moisture ingress etc etc etc but at the point of ripping the lot out.
    I’ve recently put in a SanDisk MaxEndurance 64GB MicroSDxc U3 class10 card which lasted all of 2 weeks before the rapid flashing red light comes on the unit
    Prior to that I used a SanDisk 128gb Extreme MicroSDxc U3 A2 which lasted 3 months before corrupting. Prior to this I had a SanDisk MaxEndurance MicroSDxc 128gb which lasted a year and also been through a few Lexar versions of the same all amounting to a year and a 9 months of use and a total of 6 memory cards.
    The camera unit is connected via a thunderbox which provides some power for a few seconds after turning the bike off. I’ve checked all connections, and they are all as they should be
    Hans replied 2 weeks, 3 days ago 2 Members · 12 Replies
  • 12 Replies
    2025-06-21 at 00:29
    Hi Luke,
    What setting did you use for ‘Loop Recording’?
    And how do you format the SD cards?
    How did you connect the yellow wire? Did you also connect the red and black wires to the Thunderbox? These are also switched by the Thunderbox?
    • lukec
      2025-06-21 at 00:34
      Hi Hans, thanks for your reply. I’m keen to get this sorted as it’s become annoying and unnecessarily expensive to have it now.
      Loop Recording is set to continuous overwrite. I format the SD cards from within the app but I’ve also tried formatting via my windows PC to FAT format too.
      I don’t have a yellow wire in my K6 dash cam (it was one of the first production ones ordered the moment they released in the UK, not sure if that makes a difference). I have a white wire as an extra but don’t use that as per the manual.
      Red and black wires are connected to the relevant ports on the thunderbox and the thunderbox manages the power to the K6. Hope that helps
      Power to the unit seems good, but I get the rapid red flashing light whenever one card breaks.
      • This reply was modified 3 weeks ago by  lukec.
    2025-06-21 at 00:50
    Hi Luke,
    It is recommended to only format the SD cards using the Innovv app. An SD card formatted with a computer can sometimes cause problems. Innovv cameras sometimes cannot handle an SD card formatted by a computer.
    I suspect that the white wire is the same as the yellow wire. So the switch wire. You should use this. If the K6 is switched off suddenly because the voltage on the red and black wires drops, this will certainly cause problems. The current recording cannot be closed properly and the SD card can also become corrupted.
    • lukec
      2025-06-21 at 01:02
      Forgive me I just went and checked – the Yellow wire is there, it’s connected into the port as the Red wire terminals on my thunderbox
      I’ve formatted one Lexar card using the PC as I wanted to try it bearing in mind every other time I format is via the Innov app
      • lukec
        2025-06-21 at 01:10
        For reference for setup
    2025-06-21 at 03:12
    Hi Luke,
    I think I see the source of the problem.
    You have the yellow wire connected to the red wire. And that is a ‘no-go’ and the ultimate recipe for problems.
    The red and black wires should be connected to a constant plus and minus. The yellow wire should be connected to a switched power supply.
    • lukec
      2025-06-21 at 04:11
      I thought the thunderbox is designed to effectively a bit switched connector hence the set up… Can I put the yellow wire into another one of the green/black thunderbox terminals then? Or do I have to feed it somewhere else entirely?
      Btw I appreciate your help with this
    2025-06-21 at 21:10
    Hi Luke,
    I am not familiar with systems like the Thunderbox, ezCan and such. But it seems to me that you can set the Thunderbox to switch in some way. The fact remains that the Innovv cameras need a constant and a switched power supply. Therefore never connect the yellow and red wire together.
    You could connect the K6 directly to your battery and let the yellow wire switch through the Thunderbox.
    • lukec
      2025-06-22 at 02:30
      I’ve got some crimps coming tomorrow to connect the wire to a connector for the battery terminal to give that a go as a back up. I’ve separated the red and yellow wires into their own blocks in the green output of the thunderbox (according to feedback online) and this does sort it – although it appears my rear camera is dead, even though all connections seem fine. Going to check in a week as it may just have been the fact I formatted the card but on “live view” I had a blank black screen for the rear camera
    2025-06-22 at 15:53
    Hi Luke,
    You could remove the rear camera and reinstall it. Maybe it was a loose/dirty contact.
    Possibly also reload the firmware. It could be that the firmware has also become corrupted due to all the malfunctions, causing the rear camera to no longer work.
    Also make sure that the cables are not too tight. Due to the vibration of the bike, tightly tensioned cables can also become defective.
    • lukec
      2025-06-23 at 21:12
      Still looking into the loss of the rear camera but directly connected the positive to the battery, leaving the negative and the yellow connected to the thunderbox.
      I came back to the bike overnight to ride in to work to find it had seemingly been on all night with my trickle charger plugged into my bike (as I do every night). Is there a way to stop this happening?
      I’ve almost defeated the point of having thunderbox as it’s designed to regulate the power through lots of devices through the bike (and my dash cam was the only thing I had using it as scottoiler didn’t behave well with it and three of those went faulty!).
      Checked the wiring connections and that all seems fine. Want to avoid the flashing the firmware as I’m worried I’ll break it even more
    2025-06-24 at 02:13
    Hi Luke,
    I think the trickle charger has activated the Thunderbox somehow.
    Why not also connect the – directly to the battery?
    The K6 requires minimum current when it is switched off, so you don’t have to worry about draining the battery.
    If you have connected the – to the battery and you hold the yellow wire against the + of the battery and the K6 starts up well, works well and if you disconnect the yellow wire from the + of the battery and the K6 switches off well, then you know that the K6 is working well. You should then look for the problem with the Thunderbox.
    In general, the experiences with Thunderboxes, exCan here on this forum are not positive.
    As for the firmware update, you can (almost) not break anything. Use an 8 to 32Gb SD card for the update. And if it doesn’t work, you can always perform the firmware update again.
