Forums › Forums › K7 Dashcam › Continuous recording problem
  • Continuous recording problem
    Posted by Darran on 2025-08-28 at 03:21
    Hello I can only have 1 minute loop clips so far, I was on a track day and went to settings and put in continuous recording but as soon as I closed my phone and put it in my leathers it reverted back to 1 minute loop recording only, and only recorded me exiting and entering the pits and no 1 minute circuit clips
    Any help appreciated as I cannot figure what to do
    Hans replied 1 year, 2 months ago 3 Members · 5 Replies
  • 5 Replies
  • Bob
    2025-08-28 at 06:35
    Have you looked for the app update in the Apple store? If iphone of course.
    • Darran
      2025-08-29 at 03:17
      Will do that now, and yes I am an iPhone user
    2025-08-28 at 16:57
    Hi Darran,
    Which Innovv app and phone are you using?
    If you change a different setting, is it saved?
    Were recordings made while driving in and out of the pits, but were there no recordings made while driving on the track?
    When you closed your phone, were you still in the app settings for “Loop Recording Duration”? Or were you already back in the app?
    • Darran
      2025-08-29 at 03:14
      Hello
      I am using Innovv photo and video app in the Apple Store on my iPhone it is a block of red with IN, in white letters, I now also see INNOVV K2 and INNOVV H5 available but not used these,
      I changed to remove speed from recordings and this was ok and stayed changed
      I changed to continuous video in settings in app, but would not stick, and yes recorded pit exit and entry but no track time
      When I changed to continuous all I did was “close” my phone to put it in my pocket, I did not close the app as I used the app to open my phone screen to start recording then locked phone to store in pocket
      • This reply was modified 1 year, 2 months ago by  Darran.
    2025-08-30 at 14:38
    Hi Darran,
    If the K7 is connected according to the manual, including the yellow wire connected to a switched power supply, you don’t need to start recording with the app. The K7 automatically starts recording when the yellow wire receives power.
    You might think you’re starting a recording with the app, but you’re actually stopping the ongoing recording.
    I assume that when you return to the pits, you’ll also stop the recording yourself with the app.
