Forums › Forums › K3 Dashcam › Default password not recognised
Posted by Tony on 2026-02-26 at 00:23Hi all, bought a second hand K3 a while ago and just got round to fitting it. All looking good but when I try to log in to wifi says default password not recognised (12345678).
Help appreciated
Cheers
This discussion was modified 9 months, 1 week ago by
Tony.
Hans replied 8 months, 2 weeks ago 3 Members · 18 Replies -
Hi Tony,
Download the latest firmware from the Innovv website and install it: https://innovv.com/pages/k3-dashcam-support
Everything will then be reset to factory settings, and your password will be reset to the default password of 12345678.innovv.com
INNOVV creates innovative motorcycle safety products that enhance your riding safety. Our products are the top choice for premium brand, high-end design, and reliable quality.
I have fixed the password error.. 1st, i found a K3 bin file i had downloaded in Oct 2025 (i don’t think it has changed since). 2nd, I re: formatted the SD card again in FAT32, then i opened the SD card and dragged and dropped the K3 bin file into it. 3rd, with the motorbike ignition off I disconnected the power to the K3 cam module and “then” inserted the SD card into the K3 module under the seat. 4th, I reconnected the K3 cam modules power and turned on the motorbikes accessories, the K3 module began to install the bin file “the green video camera icon began to flash fast”. I waited 5 mins for it to completely install. Then using password 12345678 it worked.
This reply was modified 8 months, 4 weeks ago by
Peter.
Hi Peter,
Thanks for the feedback. Glad the problem is resolved.
Have fun with your K3. -
Hi Hans, I’ve still not resolved the problem as I cant get the camera to connect to the app. Still trying. Will respond again soon. Cheers Tony
Hi Tony,
Do you see the K3’s Wi-Fi network (something similar to INNOVV_K3_xxxx)?
Are you connecting with an Android or iPhone? iPhones sometimes have trouble connecting. In that case, I recommend putting the iPhone in Airplane mode and manually connecting to Wi-Fi.
Which version of the Innovv app are you using?
Do you have a VPN or antivirus/firewall enabled on your phone? If so, disable them.-
Hi Hans, No problem seeing the wifi link on my android phone and my tablet. Tried airplane mode no firewall or antivirus on phone. Just keep getting the same response ‘password incorrect’ . I cant tell what version of the app is as it wont let me in. Cheers. Tony
Downloaded the BIN file and installed it on the SD card after reformatting per Peters instructions. The camera, front and rear are now working and storing vids on the card. I can see the wifi link in my list but when I try and access the wifi am stilling getting password (12345678) not recognised. Any other suggestions appreciated please. Cheers Tony
Hi Hans, Thanks for this. That is the app screens I can see but I can get no further than the 2nd screen wont let me open any of the options. Cheers Tony
The problem seems to be connecting it to wifi. The camera is working OK and recording
Hi Hans,thanks for your replies its really appreciated. Just spent ages trying to sort it. I’ve tried on my phone and my tablet, done factory resets and a ‘hard’reset. I’ve ‘forgotten’ the network and reconnected, tried it with card both in and out. Always I get the same message saying password incorrect. The camera is connected and working fine. The blue wifi icon keeps flashing at about 1 second intervals. Totally baffled. Cheers Tony
Hi Tony,
I think you’ve tried everything possible. It’s also possible that the K3 has a defect that’s preventing it from working.
One last try? Try connecting to the K3 via Wi-Fi with a laptop. Use the laptop to find the K3’s Wi-Fi network and try connecting to it. The password is 12345678.
If you connect, open your web browser and go to 192.168.1.254 and click on INNOVVK3. You’ll then see the K3’s folders.
If all this works, the K3 is working fine, and the problem is most likely with your phone.-
Hi Hans,
Tried with a laptop same thing – says unable to connect password incorrect. 😢
Is it worth contacting the manufacturers (or even possible??)
Cheers
Tony
Hi Tony,
You could try contacting the seller.
Certainly if it’s still under warranty.-
Hi Hans,
Finally resolved the issue, Joey from INNOVV has been messaging me and told me to use an SD card smaller than 32GB (which I’d been using). I did so and it connected immediately and accepted the password. All now working properly.
Many thanks for all your help its been much appreciated.
Hi Tony,
Great that the problem has been solved and you can enjoy your K3 again.
I was aware of the issue with the 32GB SD card firmware update. However, I thought this had already been resolved in the latest firmware versions and that you could also use larger SD cards to update the firmware.
Okay, Innovv mentions the FAT32 format on their website for the K3 firmware update, but it isn’t clear that an SD card of up to 32GB is recommended in that case.Anyway, you can continue with your K3.
