Forums › Forums › K7 Dashcam › Delete videos in folders?
  • Delete videos in folders?
    Posted by tommy on 2025-07-17 at 15:11
    Hi, just installed K7 on my Harley-Davidson Pan America, camera works very well.
    I have a few questions?
    1. Does it save in accident folders when there is no incident?
    2. How do you delete videos that are in Accident and Protected once you have downloaded them?
    @INNOVV
    tommy replied 1 year, 4 months ago 3 Members · 3 Replies
  • 3 Replies
  • fatbloke
    2025-07-17 at 16:40
    Hi,
    The only way to empty all folders including saved / locked files is to format the sd card via the app.
    Files are locked only when an incident occurs dependant on the shock sensitivity settings.
    2025-07-17 at 16:54
    Hi Tommy,
    1:
    If there are no incidents, the videos are not recorded in the accident folder. Depending on the G-sensor sensitivity setting, the videos are saved in the accident folder.
    You have to find the correct G-sensor setting through trial and error. Set the G-sensor to the most sensitive setting. Go for a ride and check the recordings. Set the G-sensor to a slightly lower sensitivity and check the recordings. Reduce the G-sensor sensitivity until no recordings appear in the accident folder during a normal ride.
    2:
    You can only delete protected files by formatting the SD card using the Innovv app. Please note that this will delete all recordings, including those in all other folders.
    You can also insert the SD card into your computer and then empty the accident folder. This is not recommended, as the Innovv camera may then no longer be able to handle the SD card properly.
  • tommy
    2025-07-17 at 17:03
    @Hans and @Fatbloke <div>
    Thanks for the answers.
    I will check out
    </div>
