Forums Forums K6 Dashcam Double-sided tape recommendation – high temperature
  • Double-sided tape recommendation – high temperature
    Posted by John on 2024-06-24 at 20:31
    For K6 users who live in temperate climes, this may not be a big deal. For desert nomads, it is a big deal. The double sided tape that comes with the product is strong enough to hold the smaller, lighter rear camera in place. Not so with the front camera. I am trying to avoid bolting through a plastic panel.
    ‘Any suggestions for a tape that is stronger in high temperatures than 3M VHB?
    Hans replied 1 year ago 2 Members · 1 Reply
  • 1 Reply
    2024-06-25 at 00:20
    Hi John,
    I have had good experiences with the 3M VHB tape in warm/hot conditions.
    But then it’s not just a matter of quickly sticking it on and hoping it stays put.
    I thoroughly clean the surface where the tape will be applied. No grease or other dirt should be present. I then warm the surface thoroughly with, for example, a hairdryer. I also warm the tape. Then stick the tape and press firmly for a while. Only then do I place the part to be glued on the tape with the same cleaning/heating actions. I also ensure that there is no mechanical tension. So do not tighten the cables too tightly, causing the camera to pull on the tape.
    Unfortunately, I have only had lesser experiences with brands other than 3M.
