Forums › Forums › K7 Dashcam › FAT32 or EXFAT does it matter
  • FAT32 or EXFAT does it matter
    Posted by Graham on 2026-05-12 at 22:16
    My Samsung microSDXC UHS-I card came formatted EXFAT but innovv only mention FAT32.
    my system only seems to be saving all the time yey only get a few videos on the card, these videos are only 30ish seconds long instead of the specified 3 minutes.
    tried all the previous advice already.
    I deleted the files off the card via the PC, inserted the card into the K7 powered up for 15 minutes and all thats appeared on the card is the files and folders that I had just deleted (32 seconds in length with a bird flying past the workshop)
    Gray
    • This discussion was modified 5 months, 2 weeks ago by  Graham. Reason: added info
    Steven replied 1 month, 2 weeks ago 3 Members · 5 Replies
  • 5 Replies
    2026-05-12 at 23:22
    Hi Graham,
    It is best to format the SD card using the Innovv app. This way, the SD card is configured correctly for the K7. My advice is also to format the SD card with the app if you have read the SD card in a computer. It can sometimes happen that when an SD card is read in a computer, something is changed on the SD card that prevents the K7 from working with the SD card properly.
  • Graham
    2026-05-13 at 00:30
    Hi Hans.
    The K7 using the app does not format this card (512gb with EXFAT). Hence my question about Fat32 vs EXFAT
    The K7 works with a smaller card running at 110mb/s and have done the software update (the file disappears afterwards which I understand is normal.
    Graham
    2026-05-13 at 01:35
    Hi Graham,
    Is the card being detected, or is the Innovv app already giving a message that the card is not seen? You could try Fat32. Fat32 offers better compatibility than ExFat. If the SD card is then accepted by the Innovv, you can still format it using the Innovv app.
    Based on my own experience with other Innovv models, it shouldn’t matter how the card is formatted.
    It is correct that with the firmware update, the update file is deleted once the update has been performed.
    • Steven
      2026-09-05 at 18:25
      I’m new to the K7. Right now it appears to be working well. I formatted a new SD card (512GB) using the app. After a ride I read the card from my W-11 pc and it sees it as an exFat.
      Does the app format the SD card as FAT32 or exFat?
      • Steven
        2026-09-06 at 18:34
        I’m asking this question because exFAT works much better on large files and on Windows, macOS and Linux. FAT32 has a broader coverage of compatibility especially on older devices and traditionally with smaller files. It might be reasonable for INNOVV to have changed the formatting to exFAT on the K7 app. Knowing the formatting would also eliminate the possible need to reformat the SD-card after each reading on a pc.
        Is there anyone from INNOVV of the Forum that can provide the answer?
