Forums › Forums › K7 Dashcam › For Dan – K7 Reboot Loop
  • For Dan – K7 Reboot Loop
    Posted by treborbmw on 2026-08-08 at 15:30
    Hi Dan,
    For some reason I can’t reply to you post, hence the new thread about your problem.
    I recently had an issue were on of my cameras failed and the K7 would stop recording after a minute or so. During the fault finding process I would reset the K7 by pressing the button on the remote for about 10 seconds until all the lights would cycle on/off then go off completely. The following day I found I had symptoms very similar to what you are having. I eventually found that the button on the remote had stuck in, causing it to continuously reset. Fiddling with it released it and everything was back to normal. INNOV replaced both the remote and the faulty front camera under warranty.
    It could be that either the button on your remote is stuck in, or fault has developed shorting it out. Try playing with the button to see if it stops the cycling. Failing this, I think you can run the unit with the remote disconnected. Give this a try and using your phone check the K7 is recording normally.
    Hope that helps!
    Bob
    treborbmw replied 3 months, 1 week ago 1 Member · 0 Replies
  • 0 Replies
Sorry, there were no replies found.
