Forums › Forums › K6 Dashcam › Front Camera Issue
  • Front Camera Issue
    Posted by John on 2026-06-05 at 02:11
    I have a k6 dash cam just over a year old. I took the SD card out to download it’s content and since then the front camera has stopped powering up. I’ve tested the camera on external power, downloaded the latest firmware to the card but it still no longer powers up. Has anyone had similar or have any advice?
    John replied 4 months, 3 weeks ago 3 Members · 7 Replies
  • 7 Replies
  • Dean
    2026-06-05 at 02:46
    Sorry can’t help but how much longer over a year have u had and where did U get it from?
    Try a common electrical trip and hold on button down for a while. U never know
  • John
    2026-06-05 at 03:12
    Amazon in March 2025, fitted in April and no hanging on to the power button hasn’t worked either.
  • Dean
    2026-06-05 at 03:19
    Did it work on external power?
  • John
    2026-06-05 at 03:30
    Apologies forgot to mention. no, external power is still the same.
  • Dean
    2026-06-05 at 03:44
    Mmm not sounding good I’m afraid 😨
    2026-06-05 at 14:57
    Hi John,
    Did you use an external power supply that can deliver enough power, at least 2A?
    Is there a rubber ring on the cover near the SD card slot? If not, moisture may have gotten into the K6.
    You can charge a phone using the USB-C connection on the K6 power supply; if so, the power supply is fine.
    Try starting the K6 without the rear camera connected. And starting it without the SD card, does that work?
  • John
    2026-06-05 at 22:55
    Hi,
    Minimum external supply was 3.1 amps and the power on the bike is fine as is the rubber seal on the connector. I’ve given it another try without the card but it’s still not powering up.
