Forums › Forums › K6 Dashcam › Front camera screws
  • Front camera screws
    Posted by David on 2026-05-24 at 21:16
    Hello everyone ,im probably not the first but ive lost the two front camera screws on my innov k6,thought they were tight enough but obviously not ,does any member know the diameter and thread size or in fact if its possible to buy new ones
    Thanks in advance Couerdelion
    David replied 4 months, 4 weeks ago 3 Members · 19 Replies
  • 19 Replies
    2026-05-24 at 22:11
    Hi David,
    I don’t know the specifications of the screws. I assume you mean the screws that provide access to the SD card.
    You can contact Innovv. I think Innovv can supply you with the screws.
    Contact Innovv can be done here https://innovv.com/pages/contact
  • David
    2026-05-24 at 22:34
    Thanks for the quick and helpful reply Hans,I’ll have a look ,enjoy the rest of your weekend cheers Couerdelion
    • adamgiles
      2026-05-25 at 00:04
      If Innovv aren’t helpful, give me a shout and I can measure the thread sizes for you.
  • David
    2026-05-25 at 02:53
    Thankyou for the reply Adam ,thats very helpful, ive tried a few from my collection and found 2 that are the correct thread
    Regards Couerdelion
  • David
    2026-05-26 at 00:42
    Thankyou Hans and Adam for your help ,turns out id had a senior moment and whilst playing around and setting up id forgotten to put the thumb screws in ,found them in the box !!! Panic over
    Next problem is recording footage ,rear camera perfect but front camera ,freezes goes all pixalated ,starts then stops, goes pixalated again ,am I trying to record at too high a resolution?
    Cheers Couerdelion
    • David
      2026-05-26 at 01:07
      Im watching footage via the sd card in a computer not using the WiFi phone app
  • adamgiles
    2026-05-26 at 01:39
    What spec is the sd card? What format are you recording in on front camera?
    Also, how are you connecting the sd card to you computer?
  • David
    2026-05-26 at 01:46
    Hello Adam,I’m using a micro sd adaptor, a SanDisk extreme 128gb U3 v30,not sure about the camera format though but will try to find out tomorrow
    Regards Couerdelion
    • adamgiles
      2026-05-26 at 15:19
      That seems about right.
      And the picture interference is at the same point every time you play it back?
      Just trying to confirm if it’s a playback issue or recording issue…🤔
  • David
    2026-05-26 at 17:15
    Hello Adam yes it shows a still picture then pixolates then another still picture of footage further on the recording ,its the same time aoart at about 2 second intervals ,the sound is okay and not interrupted
    Cheers Couerdelion
    • adamgiles
      2026-05-26 at 19:26
      Did you format the sd card in the camera?
  • David
    2026-05-26 at 20:24
    Hello adam,I formatted it when I tried it in the house but not when fitted to the bike, im going to have a play around later today ,bit hot here at the moment and im building a new kitchen!!🥵
    Regards Couerdelion
    2026-05-27 at 17:24
    Hi David,
    The SD card specs are fine.
    Which software are you using to view the images on the computer?
    Do you have the same playback problem on another computer as well?
    It is also recommended to format the SD card using the Innovv app. This ensures the SD card has the correct file indexing.
    Good luck with building the new kitchen.
  • David
    2026-05-27 at 22:25
    Hi Hans thanks for the reply,ive a techo savvy mate visiting tomorrow so ill pass all yours and Adams helpful advice onto him as computer terms are his second language, me and technology dont seem to get on those 0 and 1 really dislike me 😆. Unfortunately we only have the one computer and thats mainly for printing labels off ,ill try the format thing again, I formatted it via a 240v USB thing in the house before fitting it to the bike ,when I used the innovv app to set the cameras up the picture was nice and clear on the phone not pixalated or freezing ,ill let you know what happens tomorrow and the kitchen is putting up a good fight but I think ive got it worried now 🤣
    Cheers Couerdelion
    2026-05-28 at 15:32
    Hi David,
    I would like to hear if it worked with the K6.
    If the picture is still not good, try setting a lower resolution. This is to rule out whether the phone/computer you are playing the video on is fast enough for a higher recording resolution.
  • David
    2026-05-28 at 16:30
    Hi Hans ,ill let you know how I get on,it always annoys me when people dont reply as to how they solved their problem ,like you say its probably a resolution setting, im not posting my ride outs on social media ,not sure if youre aware but its actually illegal to do so in france ,any dash cam footage is only to be shared with either your insurance company or the gendarmes
    Cheers Couerdelion
  • David
    2026-05-29 at 00:09
    Hello Hans and adam ,my computer savvy mate had a play with the resolution on the front camera ,apparently it was too high ,all numbers to me but i did hear 2.5k dropped to 1950 and 1440 ,means nothing to me, card was reformatted via the innovv app , tried it out in the garage then checked the footage on the computer and no freezing or pixalation,all seems well so when its a bit cooler ill have a ride out.
    Thanks again for all the advice Regards Couerdelion
    • adamgiles
      2026-05-29 at 05:25
      Hi David.
      K6 should be capable of recording 2k on front camera, but if you are happy with 1080 then that’s great.
      It will also allow more recordings before the sd card is full 👍
  • David
    2026-06-02 at 02:15
    Thanks for the reply Adam ,it seems to work ok ,I dont think its set at 1080 but the next one up maybe 1950×1440 ? ,dont quote me on that though im old school so not tech savy enough, I went for the innovv k6 specifically just for ease of it self starting with the ignition for safety incase of a accident so the insurance can see who is at fault and my widowed wife gets the insurance payout 🤣
    Cheers and ride safe Couerdelion
