Forums › Forums › RC6 With Dashcam & ThirdEYE › I can’t see all my recorded videos in the app
  • I can’t see all my recorded videos in the app
    Posted by Alex on 2026-10-17 at 03:35
    Early in September this year, I purchased this product and started recording videos without any issues. The only thing I’ve observed after mounting the product on the motorcycle is that the front camera’s LED is continuously green and blinking red. I’ve tried pressing the front camera button several times to see if there were any changes, but I haven’t noticed a difference. The main problem is that I can’t see all the videos in the app. I’m not sure if it could be because I have a setting that records videos minute-by-minute in high quality, and the mobile device can’t process the entire list, but either way, I can’t view all the videos in the application, and it’s quite frustrating.
    Also, they appear very intermittently; I only see the ones I created at the beginning and the ones from a month ago.
    The card I purchased is a Samsung 256 GB card that was sold to me at the store itself. I understand it is optimal and compatible for storing these videos.
    Please let me know if you have any suggestions or what I should check, because I can’t think of anything else, and removing the card to copy files directly from a microSD reader doesn’t seem like an option to me. I liked this system and purchased it because it gives the option to copy files via the camera’s Wi-Fi, although I must say the experience so far is that it copies very slowly.
    I’ve tried everything with the app: clearing the cache, clearing all data, uninstalling and reinstalling, and none of that has worked.
    Thank you very much for your time reviewing my case, and I hope we can find a solution together. Best regards.
    Hans replied 2 weeks, 4 days ago 2 Members · 4 Replies
  • 4 Replies
    2026-10-18 at 21:39
    Hi Alex,
    The flashing of the red and green LEDs can indicate various things; please refer to the manual for details.
    Are you able to see all the recordings if you read the SD card on a computer?
    Have you formatted the SD card using the Innovv app?
    Have you set a duration for ‘Loop Recording’? If not, recording will stop once the SD card is full. If you do set a duration, the oldest recording will be overwritten when the SD card fills up, making room for the newest one (first-in, first-out).
    If you want to view recordings directly from the camera via the app, you must maintain a continuous connection to the RC6. If the Wi-Fi turns off while you are viewing them (what duration have you set for ‘Wi-Fi Active Duration’?), you will no longer be able to view the recordings directly from the camera.
    Additionally, loading all the thumbnails can take some time.
  • Alex
    2026-10-19 at 03:19
    Thanks Hans for your reply! I’ve followed your instructions, I’ll gave you feedback asap
  • Alex
    2026-11-07 at 03:59
    Hi,
    It seems to be working better now. After changing the setting from 1 minute to 5 minutes, it is true that fewer files are seen, so the application loads them better and doesn’t get so saturated. But right now I have another problem. It turns out that when I want to download one of those videos via Wi-Fi, I’ve seen that it’s 2.4 GHz, but a 5-minute video takes more than 15, between 15 and 20 minutes, and that’s too much. Isn’t there some way to make the download faster? Since it’s Wi-Fi, I understand it should go like a shot. But what I don’t want nor can do is unscrew the screws, take out the cable, take out the card, because it would force me to disassemble the camera every time I want to get a video out, and it doesn’t seem effective or reasonable to me. The thing is to be able to use the Wi-Fi and download it. I have tried, for example, to stop the recording from the application so that it is not recording and downloading at the same time because I understand that the card is more saturated by having to be reading and writing, but as soon as I turn off to stop the recording and go to the camera’s local file download menu, it starts recording again. Is there any trick to download faster?
    Thanks in advance!
    2026-11-08 at 22:33
    Hi Alex,
    Downloading video files via Wi-Fi isn’t exactly ideal…
    The download speed depends on the quality of the Wi-Fi connection. Just because it’s 2.4GHz doesn’t mean you’ll achieve maximum speeds. Factors such as bandwidth congestion (multiple users on the same channel), the distance between your phone and the camera, the use of antivirus software, the file size, and various other external influences can all play a role. In short, you shouldn’t set your expectations too high regarding download speeds. You could try using a lower resolution—which results in smaller files—to see if that improves the download speed; it’s essentially a trade-off between quality and speed.
    In my opinion, the Wi-Fi connection is really only useful for adjusting camera settings via the app or perhaps downloading the occasional individual video file. The fastest way to transfer multiple videos is to remove the SD card and read it directly on a computer.
    Reading from or writing to the SD card won’t cause it to fill up any faster; after all, this is exactly what the RC6 does during normal operation.
