Forums › Forums › K7 Dashcam › Is last firmware update corrupted?
  • Is last firmware update corrupted?
    Posted by Terence on 2026-05-05 at 01:16
    I have bought 2 new SD cards now of 256 A1 U3 and when I put them in both say no card! I then formatted on my desktop and tried again and still not recognised? I think Innovv should check the firmware to make sure it recognises larger capacity cards. Maybe supplying the correct card with the unit would help?
    Hans replied 5 months, 3 weeks ago 2 Members · 1 Reply
  • 1 Reply
    2026-05-05 at 14:23
    Hi Terence,
    The K7 supports cards with a capacity of up to 512GB, so a 256GB card shouldn’t be a problem.
    Does the previous SD card you used still work without issues? You can purchase the correct card for the K7 on the Innovv website: see https://innovv.com/collections/k7-accessories/products/evo-plus-adapter-microsdxc-512gb
    If you are unsure about the firmware, I don’t know which version you have, but I might have an older version available.
    Do the new cards click into the slot properly?
    In what format do you format the cards using the computer?
