Forums › Forums › K3 Dashcam › K3 rear camera doesn’t work
  • K3 rear camera doesn’t work
    Posted by Andriy on 2025-08-15 at 04:55
    Rear camera stop working. No video from rear camera and when I tried to see image from rear camera on app – I just saw image from front camera. I did troubleshooting and found out next.
    – cable for rear camera look an feel good
    – when I tried reversed cameras to recognize if rear camera doesn’t work I just found out if I did it on working connection rear camera didn’t show up and front camera image frozen
    – I tried do it one by one. when I disconnect front camera – WiFi doesn’t work.
    – I connected front camera in rear plug – WiFi doesn’t work
    – I connected rear camera in front plug – WiFi doesn’t work
    Any suggestion what is broken – DVR or rear camera?
    Andriy replied 1 year, 2 months ago 2 Members · 6 Replies
  • 6 Replies
    2025-08-15 at 14:30
    Hi Andriy,
    You’ve done the right thing to determine that your rear camera is broken.
    The fact that you don’t have Wi-Fi on the broken camera is correct. A working front camera must be connected for Wi-Fi to be active.
    Conclusion: the rear camera is broken.
    • Andriy
      2025-08-16 at 06:00
      Thanks for answer. Now it looks like I need to order new rear camera 🙂
        2025-08-16 at 15:47
        Hi Andriy,
        If the K3 is still under warranty, I would contact the seller. You might be able to claim a new camera under warranty.
        • Andriy
          2025-08-17 at 09:58
          Thanks but I bought this camera more than three years ago.
    2025-08-17 at 15:49
    Hi Andriy,
    You can order spare parts on the Innovv website.
    https://innovv.com/collections/k3-dashcam-accessories/products/innovv-k3-k5-camera-set-k3-2-0-meter-6-5-feet
    • Andriy
      2025-08-18 at 05:29
      I already check it. I use it for front camera. I will order with 1.5 m cable.
