Forums Forums K5 Dashcam K5 only record when it feels like it.
  • K5 only record when it feels like it.
    Posted by expo on 2024-10-07 at 21:17
    I’ve the K5 installed on my bike and if I look in the recordings , it only records from time to time. On a day trip I’m glad to have an hour of recording. I tried different brands of SDcards, different sizes, no cheap stuff, Sandisk, Samsung and lexar, fast cards its the same everytime. Only records from time to time. For me its a non reliable piece of junk that I probably will remove cause It isn’t doing what a dashcam should do, record.
    I was wondering If I’m the only one with this issue.
    Hans replied 1 month, 2 weeks ago 4 Members · 10 Replies
  • 10 Replies
    2024-10-07 at 23:38
    Hi Twan,
    The recordings are not saved in the accident folder? IF so, then your G-sensor is too sensitive.
    Failure of the K5 can have several causes. Think of loose connectors, no good supply voltage, incorrect connection of the yellow wire, connection via an eZCan that is not configured correctly, etc. etc.
    Do you see the recording LED on the remote control light up all the time while driving? This is to see if there is no voltage interruption.
    How/where did you connect the power converter? Is the blue LED on the power converter lit.
    Are you able to measure the battery voltage while the engine is running?
  • expo
    2024-10-08 at 22:04
    I’ve checked everything again.
    Bluelight is burning, It started to blink for a moment when I turned off the power, but then it was steady blue again. If I wiggle with the unit, the connection onthe battery it wont blink.
    The voltage on the bike while driving is around 14.2V
    The yellow cable was connected, but I reconnected it, I saw the copperwiring so I changed it.
    The power converter is connected directly on the battery.
    But as you mentioned the recording LED isnt always steady. Sometimes while driving it starts to blink.
    I’ll try it out one of the days to make sure, maybe it was the yellow cable. If not I’ll reconnect it from scratch.
    2024-10-08 at 23:50
    The power supply is good.
    The fact that the blue LED flashes briefly should not be a problem.
    The fact that the recording LED sometimes flashes seems to me to indicate a card problem.
  • expo
    2024-10-09 at 00:08
    Its a slow flash, so no recording. I just did a little ride to get some fuel and the first minute or so it records, then nothing anymore. flashing record button. When I started at the gasstation, solide light and again after a few moments it flashing. I checked the card and everytime I have to stop for traffic it records. So the card can be the problem if its not fast enough. If you stand still the image is almost not changing. I now replaced it. I’ll check it one of the days if that was the issue.
    • expo
      2024-10-20 at 00:56
      And its like you thought, I changed it with an other card and de light started flashing fast, I put in another card and now its working. Find it strange cause I used them before without a problem.
      Anyway, for me its resolved. Thanx
    2024-10-20 at 02:07
    Hi Twan,
    Thanks for the feedback and good to hear that the problem has been solved.
    Maybe the SD card got corrupted and started to give problems. After all, an SD card is just a kind of piece of technology that can also break down.
    Enjoy your K5.
  • david
    2025-02-14 at 21:32
    I am almost the same problem as Twan, My K5 records for about 30 minutes (in 5 minute settings) then for some reason it just stops recording. The lights on the RC are all on as they should be but it is as if the camera has just locked up – I have tried pressing the button once and twice (save video / take photo) and this does not work.
    And yes, I am using high quality 256gb Samsung Pro cards, I have also tried the Sandisk equivalent both with same result – I believe both cards are recommended by Innovv. I am 100% confident it’s not the SD/TF cards at fault here.
    Quite frankly, I am now just getting fed up and unless Innovv come up with a solution soon then I will be ripping it off the bike and binning it as its simply not fit for purpose at moment. Feedback will also follow and may make a nice YouTube review to warn other potential buyers. I have so far spent about 10 hours of testing and trying to get this all sorted and it’s still not working. I am hopeful Innovv Support will come up with a fix soon because otherwise the video quality is top notch, but that’s only useful if the ruddy thing works…..
    • This reply was modified 4 months, 1 week ago by  david.
    2025-02-14 at 23:45
    Hi David,
    Does the K5 freeze every 30 minutes, or is it a different time each time?
    How do you have the wifi timer set?
    Did you format the SD cards using the Innovv app?
    Are all connectors properly connected?
    If the K5 freezes, can you check whether something ‘electrical’ has happened, for example turning on lights, using the horn, etc. Can you also measure the battery voltage? The LED on the power module, is it lit or flashing and if so, what color? Can you power the K5 with a USB power bank? First disconnect the power module. This is to see whether the problem is in the power supply or the power module.
    Have you also tried to flash the firmware again?
    You have been testing for over 10 hours, what and in what way did you test everything?
  • craig
    2025-05-05 at 11:34
    I have a new 2024 R1300GS and had all the wiring done and verified. Worked for a little bit and today, when I went to review the today’s rides I had 15-20 minute lapses between recordings. ARG!@!!
      2025-05-06 at 17:13
      Hi Craig,
      Can you give more info about what you have already checked?
      Think about:
      • is the power supply good?
      • are all connectors properly connected?
      • are the missing recordings not in the accident folder?
      • is your SD card good enough for the recordings?
      • can you check what happened at the moment the recording stops?
      • etc.
