Forums › Forums › K6 Dashcam › K6 WiFi connection
  • K6 WiFi connection
    Posted by Dave on 2026-03-19 at 14:37
    Having issues with connecting both INNOVV K6 and carpuride 502 via WiFi. I can get the INNOVV camera to work, had a ride today and no issue with the camera setup. However when I go and Connect my carpuride, the WiFi knocks off the INNOVV K6. Tried several times. But it seem to have one or the other. I have a IPhone 14. Any help much appreciated.
    Hans replied 7 months, 1 week ago 3 Members · 4 Replies
  • 4 Replies
    2026-03-19 at 15:08
    Hi Dave,
    If you have a Wi-Fi connection with the K6 and you want to connect another device to your phone via Wi-Fi, the connection with the K6 will be lost. Your phone can only establish one Wi-Fi connection at a time. So either with the K6 or with the Carpuride 502
    • Dave
      2026-03-19 at 15:32
      Hi Hans, thanks for that. I don’t seem to be able to run the K6 with no wifi. should it and can it work via Bluetooth without wifi?
      • adamgiles
        2026-03-19 at 16:32
        Hi Dave.
        The K6 will work fine without connecting to your phone (switching on and off with ignition), but obviously the app won’t work if not connected.
        K6 doesn’t have Bluetooth .
    2026-03-19 at 16:38
    Hi Dave,
    Basically, you only need the Wi-Fi connection to the K6 if you want to change settings on the K6 and if you want to download videos.
    For normal use, you do not need the Wi-Fi connection to the K6.
    The K6 does not have Bluetooth.
