Forums › Forums › K7 Dashcam › K7 accident folder
  • K7 accident folder
    Posted by Chris on 2026-09-04 at 19:20
    I recently bought the K7 and installed on my bike, it seems to work but the camera light flashes after a couple minutes of riding. I notice it saves the first few minutes to continuous folder but all the other recordings inside the accident folder. I have tried to set the g sensor to its max , it was set to 2 bars initially but it still saved into accident folder, I have tried to disable the accelerometer and it still records into the accident folder and the camera light is slow flashing. The recordings no longer show x,y and z axis so this suggests it is disabled correctly . Any suggestions? The unit is powered directly from the battery and the yellow wire to acc wire so it does switch on and off with ignition. the parking function is enabled
    • This discussion was modified 1 month, 1 week ago by  Chris.
    Chris replied 1 month, 1 week ago 2 Members · 2 Replies
  • 2 Replies
  • Steven
    2026-09-05 at 18:31
    Hi Chris,
    By “accident” folder are you referring to the EMR_E folder?
    I’m new and trying to learn as much as possible. I don’t have an “Accident” folder and hoping accident and EMR_E are one in the same.
    Thank-you,
  • Chris
    2026-09-05 at 19:25
    That’s the folder I believe yes, the file has a G so has been triggered by g sensor, that’s my understanding anyway.
