Forums Forums K7 Dashcam K7 and Hex EzCan with parking mode enabled
  • K7 and Hex EzCan with parking mode enabled
    Posted by degas on 2024-09-03 at 22:18
    Hello Guys,
    I am a new owner of the InnoVV K7 dash cam. I mounted it on my BMW K1600GT where also the Hex EzCan is installed. I am not sure to have cabled the K7 in the right way but in order to have the K7 parking mode function working, I connected the K7 as follows:
    1- The black and red wires from the K7 to the black and red wires of the motorcycle battery directly
    2- The yellow wire from the K7 to the solid colored wire of one of the 3 wirse plug of the EzCan (in my case, I sued the yellow plug and I connected the K7 yellow wire to the EzCan yellow wire)
    Was I right to use the yellow wire of the EzCan or did I have to connect the K7 yellow wire to the stripe colored wire of the Ezcan (in this case white/yellow wire) ?
    Is there any kind of protection so that the K7 parking mode doesn’t work if the charge of the motorcycle battery is low?
    Thanks in advance to everybody
    Diego
    Hans replied 10 months ago 2 Members · 1 Reply
  • 1 Reply
    2024-09-03 at 23:49
    Hi Diego,
    I have no experience with the Hex EzCan. But for the switched power supply on my K1600GT (2018) I used the round connector under the passenger seat. This is the connector used to connect the topcase. It is the red / yellow wire.
    After the ignition has been switched off, voltage remains at this connection for 60 seconds.
    The K7 is, if properly secured against draining the battery.
    On my BMW I have no problems with draining the battery. I have a K3, K5, ThirdEye and an alarm system connected. I can start the motorcycle without any problems after a few weeks of standing still.
