Forums › Forums › K7 Dashcam › K7 Reboot Loop
  • K7 Reboot Loop
    Posted by Dan on 2026-08-08 at 16:22
    Hi
    I am having a major issue with my INNOVV K7 and am hoping someone here can help.
    The system has entered a continuous bootloop. When I turn the bike on, the camera lights up with a solid light for about 30 seconds. It then shuts off completely for about 5 seconds, powers back on, and repeats this process endlessly.
    This problem started immediately after I unplugged the front and rear cameras to switch them around (as my feed was originally backwards). Everything was working perfectly fine before this.
    To troubleshoot, I have already tried the following:
    SD removal
    • Switching the camera cables back to their original positions.
    • Plugging in only one camera at a time to isolate a faulty lens.
    • Unplugging absolutely everything (running the DVR unit completely bare)
    Unfortunately, regardless of what is plugged in or unplugged, the exact same fault occurs. The system just keeps looping through the 30-second power cycle.
    I tried removing SD and reinstalling also but still same issue camera lights up for around 30 secs then reboots
    Thanks in advance!
    • This discussion was modified 3 months, 1 week ago by  Hans. Reason: Message reposted so that forum members can respond
    Dan replied 3 months, 1 week ago 3 Members · 4 Replies
  • 4 Replies
    2026-08-08 at 16:23
    Hi Dan,
    Have you already tried flashing the firmware again?
    It is also possible that the button on the remote control is jammed, causing it to be pressed continuously. This can also cause a reboot.
    Can you also measure the power supply voltage to see if it is correct? A power supply voltage that is too low can also cause a camera to get stuck in a startup loop.
    PS, I have already reposted your message as an administrator so that other forum members can respond to it.
  • Dan
    2026-08-08 at 21:46
    Hello Hans,
    Thanks for your fast reply and help!
    I have checked the remote button and it seems fine—it clicks normally when I press it. I tried holding it down, but the camera light still just comes on for around 30 seconds and then reboots.
    I also checked the power supply voltage, and it is completely stable between 12.50V and 12.80V. I checked the 1A inline fuse as well, which is perfectly fine. I even tried plugging just the cameras directly to the battery, but sadly, the exact same issue occurs.
    I haven’t tried flashing the firmware yet, as everything was working completely fine until this boot loop started.
    <hr jsaction=”” jscontroller=”llbKvd#iOlsLd” data-sfc-root=”ep” jsuid=”Lp8bAb_1o” data-sfc-pl=”|||[]” data-complete=”true” data-processed=”true” data-sae=”” data-copy-service-computed-style=”font-family: "Google Sans", Roboto, sans-serif; font-size: 13px; font-weight: 400; margin: 32px 0px; text-decoration: none; border-bottom: 0px rgb(128, 128, 128);”>
  • treborbmw
    2026-08-08 at 22:34
    Hi Dan,
    I’m not sure if you saw my previous message which I posted in a new thread when I couldn’t reply, but here it is again in case you missed it:
    Hi Dan,
    For some reason I can’t reply to your post, hence the new thread about your problem.
    I recently had an issue where one of my cameras failed and the K7 would stop recording after a minute or so. During the fault finding process I would reset the K7 by pressing the button on the remote for about 10 seconds until all the lights would cycle on/off then go off completely. The following day I found I had symptoms very similar to what you are having. I eventually found that the button on the remote had stuck in, causing it to continuously reset. Fiddling with it released it and everything was back to normal. INNOVV replaced both the remote and the faulty front camera under warranty.
    It could be that either the button on your remote is stuck in, or a fault has developed shorting it out. Try playing with the button to see if it stops the cycling. Failing this, I think you can run the unit with the remote disconnected. Give this a try and using your phone check the K7 is recording normally.
    Hope that helps!
    Bob
    Since I posted the above, I note you said you tried unplugging everything, did this include unplugging the remote?
    It does sound like the K7 is continuously rebooting.
    Cheers
    Bob
  • Dan
    2026-08-09 at 00:55
    Hello
    Thank you very much for going out of your way to reply. I have looked at the button and it seems to be ok. It clicks when I press it, so I guess it isn’t stuck. I will try to run the unit without the button connected and see if that does anything. These are only a few months old but sadly i didn’t think to ask the shop who installed them for the box back that I put the receipt in just my luck.
    Regards, Dan
    • This reply was modified 3 months, 1 week ago by  Dan.
