K7 Reboot Loop
Hi
I am having a major issue with my INNOVV K7 and am hoping someone here can help.
The system has entered a continuous bootloop. When I turn the bike on, the camera lights up with a solid light for about 30 seconds. It then shuts off completely for about 5 seconds, powers back on, and repeats this process endlessly.
This problem started immediately after I unplugged the front and rear cameras to switch them around (as my feed was originally backwards). Everything was working perfectly fine before this.
To troubleshoot, I have already tried the following:
SD removal
- Switching the camera cables back to their original positions.
- Plugging in only one camera at a time to isolate a faulty lens.
- Unplugging absolutely everything (running the DVR unit completely bare)
Unfortunately, regardless of what is plugged in or unplugged, the exact same fault occurs. The system just keeps looping through the 30-second power cycle.
I tried removing SD and reinstalling also but still same issue camera lights up for around 30 secs then reboots
Thanks in advance!
This discussion was modified 7 hours, 43 minutes ago by
Dan.
Sorry, there were no replies found.
