Forums › Forums › K7 Dashcam › K7 sd card no click-in retainer
  • K7 sd card no click-in retainer
    Posted by sargezone on 2025-07-11 at 02:54
    heya, new user with a slightly annoying issue
    when i go to insert the sd card into the K7 unit, there is no retaining click, only thing keeping card in place is the weather protecting rubber, which cant keep the card in place for long, before the dreaded fast flashing of green light appears.
    is it just my unit or does ppl have any tips or tricks to fix ?
    Regards, a otherwise happy customer
    sargezone replied 1 year, 3 months ago 4 Members · 4 Replies
  • 4 Replies
  • fatbloke
    2025-07-11 at 04:17
    Hi,
    You just need the edge of another sd card to push it in a fraction more, ur fingers are too soft for the final click
    Tony…
  • Bob
    2025-07-11 at 06:09
    I think I use my finger nail for that extra push. Let us know if this works.
    2025-07-11 at 16:33
    Hi Jens,
    If you push the SD card all the way in, it should spring back slightly and stay in place.
    You’ll need something narrow to push the SD card all the way into the DVR. Simply pushing it in with your finger won’t work. The SD card needs to be pushed in deeper than the edge of the slot.
  • sargezone
    2025-07-18 at 19:44
    so i found that taking a 2.nd sd card and using it to push the first sd card into place actually worked.
    these should be like a tool for helping to push card in place when mounted where the sd slot in hard to access or at least a tips n tricks help thing for this issue imo.
    problem solved at least.
    thx for comments
