Forums › Forums › K7 Dashcam › live feed?????
  • live feed?????
    Posted by William on 2026-02-22 at 00:21
    installed k7 on 25 wing. I have not done anything yet but when i turn on bike should i not see a live feed on my phone?????
    Hans replied 8 months ago 3 Members · 7 Replies
  • 7 Replies
  • Bob
    2026-02-22 at 01:04
    No. There is no real time display in the app.
    The app is used when you are stopped to access the files on the SD card. Format the card using the app, not your PC. You can move the SD card to your desktop to copy off the files you wish to keep.
    I ride a ‘22 Wing.
    2026-02-22 at 02:41
    Hi William,
    Could you please explain what you’ve already tried and what steps you’re taking to get a ‘live’ feed? It’s a bit of a guessing game for us. Please also indicate which phone model/brand you’re using.
    The display in the app is primarily intended to check if the cameras are positioned correctly. You will need an active Wi-Fi connection for this.
    In my experience with other Innovv cameras, the ‘live’ feed in the app is only available for a few minutes, after which the display stops. Furthermore, the display isn’t real-time, so it can’t be used as a replacement for your mirrors.
  • William
    2026-02-22 at 22:23
    I just wanna t o camera angles.But when i turn on the bike i get nothing.
    i have samsung 23 ultra.
    i have done nothing but instsll unit.
  • William
    2026-02-24 at 06:27
    then how do you set horizon on camera for correct angle????
    2026-02-25 at 15:41
    Hi William,
    Again, could you explain what you’ve already tried and what steps you’re taking to get a live image? It’s a bit of a guess for us. In short, more information than just “I’ve done nothing but set up the unit” would be appreciated.
    Does the K7 turn on or not?
    What do the LEDs on the remote indicate?
    Do you see the K7 Wi-Fi on your phone?
    How is the power connected?
    Does the yellow wire receive power when you turn on the ignition?
    Any additional information?
    Etc. Etc.
  • William
    2026-02-27 at 22:28
    yes i think ..it is turning on.
    wifi on remote flashes 0nce about every 2 seconds.
    gps on solid
    camera flashing fast. i think this is due to no card installed
    yellow hooked to accessory .
    went through app and adjusted settings.
    im not comp smart. age thing 67 sorry
    2026-02-27 at 23:34
    Hi William,
    The camera LED can indeed flash rapidly if there’s no SD card inserted.
    If the Wi-Fi LED flashes, it’s attempting to connect to your phone. It seems you’ve succeeded because you’ve adjusted your settings.
    You should now be able to access your live feed in the app via the video camera icon.
    Step by step, you’ll succeed, even with 67😉.
