memory card size
Posted by Ben on 2025-12-21 at 02:02Maximum memory card size N2 BMW
Hans replied 10 months, 1 week ago 2 Members · 3 Replies -
Hi Ben,
You’re probably wondering what the maximum card size is for the N2 BMW version.
I suspect the maximum card size is 256GB. This is because the standard N2 also has a maximum card size of 256GB. Since the N2 BMW doesn’t have cameras, it also requires less storage.
But if you want to be sure, send an email to Innovv. -
Hi Ben,
I suspect (I don’t have an N2 BMW version myself) that an SD card is only necessary if, for example, you want to store more music than the standard memory can accommodate. The same applies if you use a navigation app that uses downloaded maps (so it doesn’t work online).
