Forums › Forums › K7 Dashcam › Microphone Extension Cable
  • Microphone Extension Cable
    Posted by PFM on 2026-07-15 at 13:49
    Is there an extension cable available for the Microphone? I could use a 2M cable.
    If not from Innovv, maybe in the aftermarket?
    Hans replied 2 months, 3 weeks ago 2 Members · 3 Replies
  • 3 Replies
    2026-07-16 at 14:46
    Hi PFM,
    There is no standard extension cable for the microphone.
    If you are handy, or have a handy acquaintance who can solder, they can extend the microphone cable by soldering a cable to it.
    • PFM
      2026-08-06 at 13:28
      Thanks. I’m pretty good with soldering and could not do this. The heat from soldering seemed to melt the insulation on the fine wires, shorting the 2 conductors together.
      I’m going to locate the mic in a reachable location with the standard length cable.
        2026-08-06 at 13:53
        Hi PFM,
        I mounted my microphone on my handlebars myself. In my situation, this is a position where the microphone is reasonably sheltered from the wind because I have a large dashboard and screen. As a result, I experience less wind noise. Make sure the foam cap stays on the microphone. Without it, you will have much more wind noise in your recording.
