Forums › Forums › K6 Dashcam › Novice dans le raccordement K6
  • Novice dans le raccordement K6
    Posted by Jean on 2026-05-05 at 13:12
    <font dir=”auto” style=”vertical-align: inherit;”><font dir=”auto” style=”vertical-align: inherit;”>Bonjour à tous , </font></font>
    <font dir=”auto” style=”vertical-align: inherit;”><font dir=”auto” style=”vertical-align: inherit;”><font dir=”auto” style=”vertical-align: inherit;”><font dir=”auto” style=”vertical-align: inherit;”>j’ai reçu mes caméras Innovv K6 hier et je ne trouve pas sur quel fil je dois raccorder le fil jaune des caméras ( moto BMW nine t 2022 ) . Pas de mode d’emploi en Français !!!</font></font></font></font>
    <font dir=”auto” style=”vertical-align: inherit;”><font dir=”auto” style=”vertical-align: inherit;”><font dir=”auto” style=”vertical-align: inherit;”><font dir=”auto” style=”vertical-align: inherit;”><font dir=”auto” style=”vertical-align: inherit;”><font dir=”auto” style=”vertical-align: inherit;”>Pourrais-je avoir de l’aide , d’avance merci.</font></font></font></font></font></font>
    Jean replied 5 months ago 3 Members · 4 Replies
  • 4 Replies
    2026-05-05 at 14:02
    Hi Jean,
    welcome to this forum.
    Would you please ask your question in English? English is the working language on this forum.
    Please also edit your message, as it is unreadable due to all the formatting characters.
  • paul
    2026-05-05 at 14:35
    <font style=”vertical-align: inherit;”><font style=”vertical-align: inherit;”>Salut Jean</font></font>
    <font style=”vertical-align: inherit;”><font style=”vertical-align: inherit;”><font style=”vertical-align: inherit;”><font style=”vertical-align: inherit;”>Le fil jaune va
    • This reply was modified 5 months ago by  paul.
    • This reply was modified 5 months ago by  paul. Reason: Mistake no in english
  • paul
    2026-05-05 at 14:43
    The yellow wire connects to the positive terminal after ignition; check your wiring diagram.
    I’m not sure where to find it on your bike, but the easiest way is to use a multimeter.
    I found this positive terminal after ignition on the connector of the 12/5-volt USB converter on my Triumph Speed Twin 1200.
    There are certainly other places to find it on the bike.
    I didn’t cut any wires, but I tinned the yellow wire to make it rigid, inserted it from the outside of this connector and secured the wire with a cable tie.
  • Jean
    2026-05-06 at 05:41
    <font dir=”auto” style=”vertical-align: inherit;”><font dir=”auto” style=”vertical-align: inherit;”>Good evening ,thank you very much for your answers everything is fine now food wheret connect the yellow wire. Thank you.</font></font>
