Forums › Forums › K6 Dashcam › Problème wifi !!!
  • Problème wifi !!!
    Posted by Jean on 2026-05-06 at 06:20
    <font dir=”auto” style=”vertical-align: inherit;”><font dir=”auto” style=”vertical-align: inherit;”>UNprès avoir arrêté la moto lorsque je veux repartir le wi-fi ne se connecte plus automatiquement ???</font></font>
    <font dir=”auto” style=”vertical-align: inherit;”><font dir=”auto” style=”vertical-align: inherit;”><font dir=”auto” style=”vertical-align: inherit;”><font dir=”auto” style=”vertical-align: inherit;”>Je ne sais plus quoi faire ?</font></font></font></font>
    <font dir=”auto” style=”vertical-align: inherit;”><font dir=”auto” style=”vertical-align: inherit;”><font dir=”auto” style=”vertical-align: inherit;”><font dir=”auto” style=”vertical-align: inherit;”><font dir=”auto” style=”vertical-align: inherit;”><font dir=”auto” style=”vertical-align: inherit;”>Avez-vous des solutions , j’utilise un iphone 13 pro.</font></font></font></font></font></font>
    Hans replied 5 months, 3 weeks ago 2 Members · 3 Replies
  • 3 Replies
    2026-05-07 at 00:30
    Hi Jean,
    Would you please ask your question in English? English is the language of this forum. You expect us to make some effort to help you with a problem, which is why I ask for some effort on your part to ask the question in English. You could use Google Translate, for example.
    Additionally, please pay attention to your message; it is full of formatting codes and is therefore difficult to read.
    Regarding your question, what have you already tried yourself? Please provide more information; the more information you have, the better we can help.
    When you want to connect, what does the LED on the K6 show? Does it blink or light up continuously, and what color(s)?
    iPhones sometimes have trouble connecting to an Innovv camera. In that case, put the iPhone in Airplane mode and connect to the camera manually.
    • Jean
      2026-05-09 at 05:16
      <pre data-placeholder=”Traduction” role=”text” tabindex=”-1″ data-ved=”2ahUKEwjg5OSfzaqUAxX1xQIHHXYnHosQ3ewLegQIFhAV” aria-label=”Mon iPhone est un iPhone 13 Pro sous iOS 26.4.2. Je peux me connecter au Wi-Fi après avoir mis le contact de ma moto. Cependant, lorsque je l’éteins et la redémarre, la connexion Wi-Fi ne se rétablit pas automatiquement. Je dois répéter la même opération à chaque fois. L’enregistrement vidéo fonctionne correctement, mais le problème est que la connexion Wi-Fi disparaît systématiquement lorsque j’éteins et redémarre la moto. J’ai joint autant d’informations que possible ; le problème vient clairement de la perte de connexion Wi-Fi après chaque arrêt de la moto. Je m’excuse de vous déranger autant, mais je ne trouve vraiment pas de solution.”>
      My iPhone is an iPhone 13 Pro running iOS 26.4.2.
      I can connect to Wi-Fi after turning on the motorcycle’s ignition. However, when I turn it off and then back on, the Wi-Fi connection doesn’t automatically reconnect.
      I have to repeat this process every time.
      Video recording works correctly, but the problem is that the Wi-Fi connection consistently drops when I turn the motorcycle off and then back on.
      I’ve attached as much information as possible; the problem clearly stems from the loss of Wi-Fi connection after each time the motorcycle is turned off.
      I apologize for bothering you so much, but I really can’t find a solution.
      <g-info-bubble jscontroller=”f3ruEc” jsaction=”rcuQ6b:npT2md”></g-info-bubble>
    2026-05-10 at 18:07
    Hi Jean,
    Could it be that you have set your phone so that it does not automatically connect to a known Wi-Fi network? On Android, this is a Wi-Fi setting that is possible. I don’t know if this is also possible on an iPhone; I don’t have an iPhone myself.
    Or does your iPhone automatically connect to another Wi-Fi network if the Wi-Fi connection to the K6 is lost? Your iPhone will then maintain this connection and will not automatically make another Wi-Fi connection, so not to your K6 Wi-Fi either when it becomes available again.
